Malum kış ayı yaklaştı. Aralık ayında da kış lastiklerine geçiş yapılacak. Lastik önerisi için gelen üyelerin fikir edinmesi açısından test yararlı olabilir.
1st: Continental WinterContact TS 860
Total: 60.2 / Dry: 7 / Wet: 7.8 / Snow: 8.2 / Ice: 7 / Comfort: 6 / Rolling Resistance: 8.6 / Wear: 8 / Overall: 7.6
Positive: Very well balanced with top marks in the wet, low fuel consumption, especially good on snow
Negative: None mentioned
2nd: Goodyear UltraGrip 9
Total: 59.6 / Dry: 7.4 / Wet: 7.8 / Snow: 8 / Ice: 7 / Comfort: 5.4 / Rolling Resistance: 8.4 / Wear: 8 / Overall: 7.6
Positive: Very balanced with top marks on wet surfaces, especially good on dry roads and snow, low fuel consumption
3rd: Dunlop Winter Sport 5
Total: 58.6 / Dry: 7.4 / Wet: 7.4 / Snow: 8.2 / Ice: 7 / Comfort: 5.4 / Rolling Resistance: 7.8 / Wear: 8 / Overall: 7.4
Positive: Very balanced winter tyres, especially good on snowy roads, very good on dry and wet roads
4th: Kleber Krisalp HP3
Total: 58.2 / Dry: 7.2 / Wet: 6.8 / Snow: 8.2 / Ice: 7.4 / Comfort: 5.8 / Rolling Resistance: 8 / Wear: 8 / Overall: 6.8
Positive: Top marks in the snow, very good on dry roads
Negative: A little weaker in the wet than the best on test
5th: Michelin Alpin 5
Total: 57.4 / Dry: 8 / Wet: 7.2 / Snow: 6.6 / Ice: 7 / Comfort: 4.8 / Rolling Resistance: 7.2 / Wear: 10 / Overall: 6.6
Positive: Best tyre in the dry and lowest wear
Negative: Slightly weak in the snow and fuel consumption tests compared to the best
6th: Nexen Winguard Snow G WH2
Total: 56 / Dry: 7.4 / Wet: 6.8 / Snow: 6.6 / Ice: 7 / Comfort: 5.6 / Rolling Resistance: 7 / Wear: 9 / Overall: 6.6
Positive: Good in the dry, low wear
Negative: Slightly wear on wet roads and in the snow, high fuel consumption
7th: Fulda Kristall Control HP2
Total: 54.4 / Dry: 7 / Wet: 6.6 / Snow: 6.4 / Ice: 7.4 / Comfort: 4.8 / Rolling Resistance: 7.8 / Wear: 8 / Overall: 6.4
Negative: Slightly weak in the wet and snow
8th: Vredestein Snowtrac 5
Total: 55.6 / Dry: 7.4 / Wet: 6.4 / Snow: 8.2 / Ice: 7 / Comfort: 4.8 / Rolling Resistance: 8.4 / Wear: 7 / Overall: 6.4
Positive: Very good in the snow, good in the dry, low fuel consumption
Negative: Relatively weak in the wet
9th: Bridgestone Blizzak LM001 EVO
Total: 57.8 / Dry: 7.8 / Wet: 7.2 / Snow: 6.2 / Ice: 7.4 / Comfort: 4.8 / Rolling Resistance: 8.2 / Wear: 10 / Overall: 6.2
Positive: Very low wear, good in the wet and dry, low fuel use
Negative: Relatively weak on snow
10th: Nokian WR D4
Total: 54.4 / Dry: 7 / Wet: 6.2 / Snow: 8.4 / Ice: 7 / Comfort: 5.2 / Rolling Resistance: 8.6 / Wear: 6 / Overall: 6
Positive: Top marks in the snow and low fuel consumption
Negative: Relatively weak in the wet, high wear
11th: Yokohama BluEarth Winter V905
Total: 53 / Dry: 6.2 / Wet: 7 / Snow: 5.8 / Ice: 7 / Comfort: 5.2 / Rolling Resistance: 8 / Wear: 8 / Overall: 5.8
Positive: Good in the wet
Negative: Relatively weak in the dry and on snow
12th: Kumho Winter Craft WP51
Total: 51.6 / Dry: 5.6 / Wet: 5.4 / Snow: 7.6 / Ice: 7 / Comfort: 5.8 / Rolling Resistance: 6.8 / Wear: 8 / Overall: 5.4
Positive: Good in the snow
Negative: Weak in the dry and wet, high fuel consumption
13th: Giti GitiWinterW1
Total: 51 / Dry: 5 / Wet: 5.4 / Snow: 8.4 / Ice: 7.4 / Comfort: 5.2 / Rolling Resistance: 7.6 / Wear: 7 / Overall: 5
Negative: Relatively weak in the dry and wet
14th: Pirelli Cinturato Winter
Total: 53 / Dry: 5 / Wet: 7.6 / Snow: 7.8 / Ice: 7.4 / Comfort: 5.6 / Rolling Resistance: 7.6 / Wear: 7 / Overall: 5
Positive: Good in the wet and on snow
15th: Semperit Speed Grip 3
Total: 51.8 / Dry: 4.8 / Wet: 7.4 / Snow: 6.8 / Ice: 7.4 / Comfort: 5.8 / Rolling Resistance: 7.8 / Wear: 7 / Overall: 4.8
16th: Laufenn I FIT
Total: 46.8 / Dry: 7.6 / Wet: 1 / Snow: 7.6 / Ice: 7 / Comfort: 5 / Rolling Resistance: 8.6 / Wear: 9 / Overall: 1
Positive: Very low fuel consumption, good in the dry, low wear
Negative: Very weak in the wet
Test Summary
Best tyre for dry roads Michelin Alpin 5
Best tyre for wet roads Continental WinterContact TS 860
Best tyre for snow Giti GitiWinterW1
Nokian WR D4
The best tyre overall Continental WinterContact TS 860
The lowest fuel use Continental WinterContact TS 860
Nokian WR D4
Laufenn I FIT
The most comfortable Continental WinterContact TS 860
The best tyre for ice Bridgestone Blizzak LM001 EVO
Kleber Krisalp HP3
Giti GitiWinterW1
The lowest wear Bridgestone Blizzak LM001 EVO
Michelin Alpin 5
Kaynak : https://www.tyrereviews.co.uk/Article/2018-ADAC-Winter-Tyre-Test-205-55-R16.htm
Test Summary
Nokian WR D4
Nokian WR D4
Laufenn I FIT
Kleber Krisalp HP3
Giti GitiWinterW1
Michelin Alpin 5
