2018 ADAC Kış lastiği testi ( 205-55-16 )
45,840
Malum kış ayı yaklaştı. Aralık ayında da kış lastiklerine geçiş yapılacak. Lastik önerisi için gelen üyelerin fikir edinmesi açısından test yararlı olabilir.
1st: Continental WinterContact TS 860
Total: 60.2 / Dry: 7 / Wet: 7.8 / Snow: 8.2 / Ice: 7 / Comfort: 6 / Rolling Resistance: 8.6 / Wear: 8 / Overall: 7.6
Positive: Very well balanced with top marks in the wet, low fuel consumption, especially good on snow
Negative: None mentioned
2nd: Goodyear UltraGrip 9
Total: 59.6 / Dry: 7.4 / Wet: 7.8 / Snow: 8 / Ice: 7 / Comfort: 5.4 / Rolling Resistance: 8.4 / Wear: 8 / Overall: 7.6
Positive: Very balanced with top marks on wet surfaces, especially good on dry roads and snow, low fuel consumption
3rd: Dunlop Winter Sport 5
Total: 58.6 / Dry: 7.4 / Wet: 7.4 / Snow: 8.2 / Ice: 7 / Comfort: 5.4 / Rolling Resistance: 7.8 / Wear: 8 / Overall: 7.4
Positive: Very balanced winter tyres, especially good on snowy roads, very good on dry and wet roads
4th: Kleber Krisalp HP3
Total: 58.2 / Dry: 7.2 / Wet: 6.8 / Snow: 8.2 / Ice: 7.4 / Comfort: 5.8 / Rolling Resistance: 8 / Wear: 8 / Overall: 6.8
Positive: Top marks in the snow, very good on dry roads
Negative: A little weaker in the wet than the best on test
5th: Michelin Alpin 5
Total: 57.4 / Dry: 8 / Wet: 7.2 / Snow: 6.6 / Ice: 7 / Comfort: 4.8 / Rolling Resistance: 7.2 / Wear: 10 / Overall: 6.6
Positive: Best tyre in the dry and lowest wear
Negative: Slightly weak in the snow and fuel consumption tests compared to the best
6th: Nexen Winguard Snow G WH2
Total: 56 / Dry: 7.4 / Wet: 6.8 / Snow: 6.6 / Ice: 7 / Comfort: 5.6 / Rolling Resistance: 7 / Wear: 9 / Overall: 6.6
Positive: Good in the dry, low wear
Negative: Slightly wear on wet roads and in the snow, high fuel consumption
7th: Fulda Kristall Control HP2
Total: 54.4 / Dry: 7 / Wet: 6.6 / Snow: 6.4 / Ice: 7.4 / Comfort: 4.8 / Rolling Resistance: 7.8 / Wear: 8 / Overall: 6.4
Negative: Slightly weak in the wet and snow
8th: Vredestein Snowtrac 5
Total: 55.6 / Dry: 7.4 / Wet: 6.4 / Snow: 8.2 / Ice: 7 / Comfort: 4.8 / Rolling Resistance: 8.4 / Wear: 7 / Overall: 6.4
Positive: Very good in the snow, good in the dry, low fuel consumption
Negative: Relatively weak in the wet
9th: Bridgestone Blizzak LM001 EVO
Total: 57.8 / Dry: 7.8 / Wet: 7.2 / Snow: 6.2 / Ice: 7.4 / Comfort: 4.8 / Rolling Resistance: 8.2 / Wear: 10 / Overall: 6.2
Positive: Very low wear, good in the wet and dry, low fuel use
Negative: Relatively weak on snow
10th: Nokian WR D4
Total: 54.4 / Dry: 7 / Wet: 6.2 / Snow: 8.4 / Ice: 7 / Comfort: 5.2 / Rolling Resistance: 8.6 / Wear: 6 / Overall: 6
Positive: Top marks in the snow and low fuel consumption
Negative: Relatively weak in the wet, high wear
11th: Yokohama BluEarth Winter V905
Total: 53 / Dry: 6.2 / Wet: 7 / Snow: 5.8 / Ice: 7 / Comfort: 5.2 / Rolling Resistance: 8 / Wear: 8 / Overall: 5.8
Positive: Good in the wet
Negative: Relatively weak in the dry and on snow
12th: Kumho Winter Craft WP51
Total: 51.6 / Dry: 5.6 / Wet: 5.4 / Snow: 7.6 / Ice: 7 / Comfort: 5.8 / Rolling Resistance: 6.8 / Wear: 8 / Overall: 5.4
Positive: Good in the snow
Negative: Weak in the dry and wet, high fuel consumption
13th: Giti GitiWinterW1
Total: 51 / Dry: 5 / Wet: 5.4 / Snow: 8.4 / Ice: 7.4 / Comfort: 5.2 / Rolling Resistance: 7.6 / Wear: 7 / Overall: 5
Negative: Relatively weak in the dry and wet
14th: Pirelli Cinturato Winter
Total: 53 / Dry: 5 / Wet: 7.6 / Snow: 7.8 / Ice: 7.4 / Comfort: 5.6 / Rolling Resistance: 7.6 / Wear: 7 / Overall: 5
Positive: Good in the wet and on snow
15th: Semperit Speed Grip 3
Total: 51.8 / Dry: 4.8 / Wet: 7.4 / Snow: 6.8 / Ice: 7.4 / Comfort: 5.8 / Rolling Resistance: 7.8 / Wear: 7 / Overall: 4.8
16th: Laufenn I FIT
Total: 46.8 / Dry: 7.6 / Wet: 1 / Snow: 7.6 / Ice: 7 / Comfort: 5 / Rolling Resistance: 8.6 / Wear: 9 / Overall: 1
Positive: Very low fuel consumption, good in the dry, low wear
Negative: Very weak in the wet
Test Summary
Best tyre for dry roads Michelin Alpin 5
Best tyre for wet roads Continental WinterContact TS 860
Best tyre for snow Giti GitiWinterW1
Nokian WR D4
The best tyre overall Continental WinterContact TS 860
The lowest fuel use Continental WinterContact TS 860
Nokian WR D4
Laufenn I FIT
The most comfortable Continental WinterContact TS 860
The best tyre for ice Bridgestone Blizzak LM001 EVO
Kleber Krisalp HP3
Giti GitiWinterW1
The lowest wear Bridgestone Blizzak LM001 EVO
Michelin Alpin 5
Kaynak : https://www.tyrereviews.co.uk/Article/2018-ADAC-Winter-Tyre-Test-205-55-R16.htm
Reddington
15 Eki 2016
1,810
MINI
Geçen kış ug9'u görmüştüm ve hatta beğenmiştim de değerlerini. Almaya niyetlendim ama Türkiye'de hep ug8 satılıyordu. Kısmet değilmiş fakat güzel lastik olduğu belliydi.
Ug7'den beri Goodyear bu konuda oldukça başarılı. Hatta Yaman abide 4-5 senelik UG7 vardı bir önceki focus'unda, yol sesi çok artmıştı ama hala canavar gibi çıktığı yerler oldu sıfır lastiklerin çıkamadığı :)
45,840
Bakalım, belki sonra ki lastikte bir de goodyear deneriz :D
Tepkiler: Reddington
45,840
yapalım bi tane 18" o Focus'a :) 225/40/18 + vogtland ya da eibach
İleride yay düşünüyorum ben de ama şu sıralar ona pek vaktim yok. Önce yay + 16 inç lastikle tutuş - konfor dengesini deneyeceğim. Beğenir ve bana yeterli olduğunu düşünürsem lastik ebatı büyütmeyeceğim. Malum, ebat büyüyünce lastik fiyatları çıldırıyor resmen :D
Reddington
15 Eki 2016
1,810
MINI
büyük ihtimalle öyle de çok tatmin eder, zaten focus ama 18 olduğu zaman direksiyon tepkileri nefis oluyor.
Beni Nokian şaşırttı.
evet ona ben de şaşırdım. daha yukarıda görmeyi beklerdim ama testler ne kadar bağımsız o da var :) pozitif ayrımcılık seziyorum ben biraz
45,840
Sürüş daha zevkli olacaktır tahmin ediyorum zaten. Ama bizim buralarda yollar pek temiz asfaltlı değil. Çukurlar boldur. Haliyle ince yanak lastik burada çok çabuk eskidiği gibi ön düzene de çok yük bindiriyor. Buna ek olarak 16'ya göre azalacak konfor + yükselecek lastik fiyatından dolayı bana çok cazip gelmiyor. He sık sık piste giren, ciddi viraj kasan biri olsam belki göze alırdım ama şuan için bana pek faydası yok maalesef yüksek ebatta lastiğin. Muhtemelen yay değişikliği beni fazlasıyla tatmin edecektir.
Hocam zaten farkındaysan lastikler arasında ki puanlamada bariz büyük farklar yok. Overall'da 1-2 puan fark sıralamayı ciddi ölçüde etkilese de günlük kullanımda ne derece fark edilir bir etki yaratır orası şüpheli.
Reddington
15 Eki 2016
1,810
MINI
yay ile oldukça keyifli ve dışarıdan görüntü olarak da çok şık duruyor. 3.5 larda kafası biraz daha yerde arabanın. yay sonrası çok dengeli oluyor. Bu fark özellikle pws de çok belli
45,840
Yay sonrası ön düzende falan bir yıpranma, tıkırtı, lıkırtı gibi sorunlar oluyor mu zaman içinde peki ?
Reddington
15 Eki 2016
1,810
MINI
ben hiç yaşamadım, fiestayı da uzun süre ve ekstra sertleştirilmiş amartisör ile kullanmıştım. Ford'ların ön takımı zaten sağlam kolay kolay problem olmuyor, yayın da ekstra yaratacağı yıpranma olacağını sanmıyorum
45,840
Eyvallah hocam.. Bakalım, önümüzde ki mayıs uzatılmış garantim de bitiyor. Garanti bitmeden dokunmuyorum araca ama ondan sonra ciddi ciddi düşüneceğim. Zaten böyle bir güncelleme de uzun zamandır var aklımda. Hayırlısı..
Reddington
15 Eki 2016
1,810
MINI
aslında daha önce de konuşmuştuk, imkanlar el verseydi o zaman değiştirseydin mükemmel olurdu. Serviste orjinal servis onaylı Eibachlar bedava rakama veriliyordu.
Ford Aksesuar'dan takip edebilirsin, life card ile vs indirim olabilir belki.
45,840
Ben garantiliyken araca dokunmayı pek sevmiyorum hocam. Aramızdan ayrılan bir üyenin ibiza cupra aracında yay var diye şanzımanı garanti dışı bırakmışlardı. Ne alakaysa :D Far ampulünü bile yetkilide değiştiriyorum ben ne olur olmaz diye. O sebeple garanti varken araca hiç dokunmadım. Bitince bakacağız o işlere. Ben de Ford Aksesuar kısmından temin etmeyi düşünüyorum zaten.
yaso
TORNACI
11,547
Antalya
Wr d4 modeli biraz eskide kaldı diğer markaların modelleri ona göre daha güncel abi. D5 mi artık ne isimle gelir bilmiyorum ama o zaman alınır. Gerçi yine d4 aldırabilecek güveni bana verdi kendisi, belki hala daha deli gibi sattığı için güncellememişlerdir
